Localisation in TM1Web
StefanWe
Excel Version: Excel 2013
Post by StefanWe »
Hi !
I struggle with localisation of application entries in TM1 web. What I want is that users should see language dependend application entries when they log in TM1 web. Means when I log via english language I want to see the websheet named „product“, when I switch to german I want to see „Produkt“ as websheet name.
I know that TM1 takes the language of the web browser settings and for the content of a websheet I get the localisation done fine, even fort he cube views.
But how can I localise websheets?
Obviously not okay or not sufficient is the following:
- create a attribute „caption“ for }ApplicationEntries
- maintain cube „LocalizedElementAttributes_}ApplicationEntries“:
o select e.g. in dimension }ApplicationEntries under Applications --> Planning --> Planning\mappe2.xlsx.blob
o Select in dimension }Cultures e.g. „en“ for english
o put in the crossing cell the value „Planung\mappe2_English“
What I would expect now is to see in TM1Web the sheet named as „mappe2_English“. But this doesn’t happen…
Thanx a lot for your help!!
