# LDAP sync
PasswordSource=LDAP
LDAPPort=636
LDAPHost=foo.bar.local
LDAPUseServerAccount=T
LDAPSearchBase=DC=foo,DC=bar,DC=local
LDAPSearchField=sAMAccountNameCode: Select all
LDAPSearchBase=CN=TM1 Users,OU=Groups,OU=Other Stuff,DC=foo,DC=bar,DC=localError 22 is described here as 'The distinguished name has an invalid syntax'. However, I know I've put the syntax in correctly as I've copied it directly from Active Directory. I thought the spaces in the DN might be the issue but I found at least one IBM technote saying that quotes shouldn't be used on this parameter, and trying it anyways didn't make a difference.tm1server.log wrote:TM1.LDAPAuth LDAP ERROR: 0x22 - search failed
Obviously, everything is working fine, so I'm not stuck - but any pointers to speed it up or configuring a better LDAPSearchBase parameter would be appreciated.
Robin
