I have created a simple Approval application using the stock SData server data in TM1 (version 10.1.1). The application is using a subset of the Region dimension as the approval hierarchy (the subset contains only a few elements). The application also has a single view - Regions (from the Sales cube). I have successfully deployed the application in Performance Modeler with no warnings or errors.
I have only one user - ADMIN. I assigned "Submit" rights for the ADMIN in the Rights section of the application.
When I launch the application, it promptly displays the approval hierarchy - the regions and the corresponding countries in those regions.
The problem occurs when I click on any of the countries. The contributor application launches and displays the splash screen, then the Regions tab appears. However, it never open the view. The Region tab keeps "working" (i.e. the little circular icon keeps turning), but nothing happens.
I can take ownership of the node.
Can anyone suggest what could be wrong?
Thank you
tm1mchs
