I need help.
Environment
TM1 10.2.2
WINDOWS 2012 SERVER
SQL 2012 ENTERPRISE.
II am getting an error when editing TI process to bring data from SQL Database.
If I run the process, result successful. If I open the process to edit the sql query TM1 hangs. The tm1 log reports
TM1.SQLAPI IM002[Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
This happens even if I reedit the SQL connection, user and password.
tm1 process
- macsir
- Version: PAL 2.0.9
Re: tm1 process
You need to figure out the version of each software and ODBC. i.e. 32-bit or 64-bit
It might be using the wrong version of SQL driver, I guess.
