Hi Everyone,
Cubewise has released some great free utilities you may find valuable on CodePlex - feedback welcomed. We had some good reviews after showing them at the most recent TM1 and Cognos Express User Conference in Sydney - we hope they help you out!
https://odbcconnect.codeplex.com/
ODBC Connect is a Windows user interface for ODBC data sources. It enables you to query both 32bit and 64bit ODBC data sources and also extract data using a command line interface. It was primarily designed and built to make life easier for developers of IBM Cognos TM1 but can be used by anyone wanting to have a graphical tool to query ODBC data sources.
https://hustle.codeplex.com/
Hustle is a small utility that can be used to manage threads when executing command line tools. The tool was built to take advantage parallel loading in IBM Cognos TM1, specifically the tm1runti.exe. Hustle enables you to specify the number of concurrent threads you want to be executed at any one time and pass a batch of commands to be executed on these threads.
https://tihelper.codeplex.com/
TI Helper is an Auto Hot Key script that can be used to enhance the options in the IBM Cognos TM1 Turbo Integrator (TI) process editor. It gives short cuts and options to generate code when using the TI editor.
Free TM1 Utilities On Codeplex
Ben H
- Version: All Versions - even 2.5
- Excel Version: All Versions
Ben Heinl, Cubewise
#DoGoodTM1
#DoGoodTM1
Re: Free TM1 Utilities On Codeplex
It might be good to move this to Useful code, tips and tricks
