Currently I am using TM1RunTI Utility to run the TI process from command prompt using windows batch file.
This utility is working fine for the TM1 application where we have normal sign on i.e. entering user id and password.
Following is the syntax which i am using to run TI process using this utility.
Syntax: tm1runti -server tm1servername -user tm1username -pwd tm1password -process TIprocessname
However when I tried to use the TM1RunTI Utility with same syntax for the TM1 application where Integrated Security is turned on it is not working.
Does anybody knows how to use the TM1RunTI Utility for the TM1 application where Integrated Security is turned on?
TM1 Version: 9.5.2
Admin Note: Moved to the correct forum. This is not an Enhancements request.
TM1RunTI Utility with Integrated Security
premalpatil
- OLAP Product: Cognos BI, TM1
- Version: 10.1 and 9.5.2
