TM1 10.2 Applications sharing cubes
Posted: Tue Aug 19, 2014 4:41 pm
by tposepny
could anybody please explain a bit more, how does sharing one cube among multiple applications work (using TM1 10.2)?
I know that one cube can be shared among multiple cubes as long as the applications are accessing different slices, but how exactly does this work with respect to approval hierarchy and control dimension? Do I have to use the same approval hierarchy and/or control dimension in all applications sharing the cube? Can I use different approval hierarchies? Do I even have to use control dimension? Isn't it good enough if I use different cube slices of the same cube in different applications (if they don't overlap) ?
Thank you very much for any details on this.
