Process doesn't delete C level elements
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Post by BariAbdul »
I am trying to delete C level elements from simple hierarchy,I have defined source as none.Below code doesn't give me any error and process run successfully but when i go back and check the dimension hierarchy is still intact.I have tried the code both prolog and epilog.Thanks
DimName = 'Region_All';
DimCount = DimSiz ( DimName );
i = 1;
While ( i <= DimCount ) ;
DimCount = DimSiz (DimName);
El = DimNm ( DimName , i);
ChildCount = ElCompN(DimName, El) ;
If ( ChildCount <> 0);
y = 1;
While ( y <= ChildCount );
ChildEl = ElComp ( DimName , El, 1);
DimensionElementComponentDelete(DimName, El, ChildEl);
y = y +1 ;
End ;
EndIf ;
i = i + 1 ;
End;
Region_All Dimension Hierarchy.doc
(38 KiB) Downloaded 338 times
Re: Process doesn't delete C level elements
As stated many times before with these kind of loops where you delete, you should loop backwards. Just as in Excel where you can delete rows in a sheet, but from the end to the beginning.
Start with your counter equal to the Dimsiz, and loop while each time subtracting 1 from the counter until you hit the element with index in the dimension 1.
Looping forward makes you miss some elements.
Use the Prolog for this kind of process, it should be done BEFORE you enter the Metadata tab.
uchow10
Post by uchow10 »
BariAbdul wrote:I am trying to delete C level elements from simple hierarchy,I have defined source as none.Below code doesn't give me any error and process run successfully but when i go back and check the dimension hierarchy is still intact.I have tried the code both prolog and epilog.Thanks
i = 1;
y = 1;
y = y +1 ;
End ;
EndIf ;
i = i + 1 ;
End;
Looking at your code I noticed your using DimensionElementComponentDelete. This function removes child from parent element, it does not delete an element. So that may be why the "C" elements are still in your dimension even though there is no longer a "hierarchy" in your attachment. If you want to delete an element use DimensionElementDelete
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Post by BariAbdul »
Thanks uchow10 ,You are correct.I realised this after posting ,It is working now.
