Hello All
I want to create TI process to put element security for all groups. There are 4000 elements and 164 groups.
Suppose i have A,B,C,D regions under Total header. I want to apply non security for everyone and Specific element security group wise as below.
First, I want to assign 'NONE' Security to all groups to all regions
Now, I want to assign 'Write' Access to region B and remaining has none access
How could apply in to TI?
Total
A
1
2
3
B
4
5
6
C
7
8
9
D
1
2
3
I thought to utilize the Element Security Put function in TI but it seems to apply manual security than this. I need some input to throw light on this issue.
Dharav
TI Process to put element security
Re: TI Process to put element security
So if you wrote it as a rule, it would go:dharav wrote:Suppose i have A,B,C,D regions under Total header. I want to apply non security for everyone and Specific element security group wise as below.
[{'4', '5', '6'}] = S: 'WRITE';
[] = S: 'NONE';
Robin Mackenzie
- Excel Version: 2013
To realise this in TI all you need is a simple loop, see code example.
In my experience fixed-security (by means of manual input, or TI) provides better performance than rule-derived security.
Surely you may need to change the IF-statement to suit your needs.
r = DIMSIZ('Region');
WHILE(r > 0);
vRegion = DIMNM('Region', r);
g = DIMSIZ('}Groups');
WHILE(g > 0);
vGroup = DIMNM('}Groups', g);
IF(ELISANC('Region', 'B', vRegion) = 1 % vRegion @= 'B');
CellPutS('WRITE', '}ElementSecurity_Region', vRegion, vGroup);
ELSE;
CellPutS('NONE', '}ElementSecurity_Region', vRegion, vGroup);
ENDIF;
g = g - 1;
END;
r = r - 1;
END;
