We've been testing TM1 Web & have noticed that when using TM1 Web & drilling to transactions, the user is able to get the SQL to complete & show the results, though once the user tries to export to either Excel or PDF, an error saying "Session Timed Out..." session will then prompt for login agian.
Anyone know which Idle Time/Time out Setting controls this?
TM1 Web Export Drill - save to Excel/PDF "Time Out"
Re: TM1 Web Export Drill - save to Excel/PDF "Time Out"
How large is the sql transaction drill that gets returned? If it is thousands upon thousands of records then I can imagine this might be a problem.
Our test was a small 10 line max result...
