TM1_API2HAN Lib "tm1.xll" not loaded
macsir
Version: PAL 2.0.9
Post by macsir »
Hi, There
I am trying to use the following code
Declare Function TM1_API2HAN Lib "tm1.xll" () As Long
in the module of my VS2010 VB.net application.
Compiling is successful but when executing to
 getUserHandle = TM1_API2HAN()
it is saying tm1.xll can't be loaded.
This code is originally used in VBA and can be run successfully. Not sure how I can convert it into VB.net to load and use it correctly?
Re: TM1_API2HAN Lib "tm1.xll" not loaded
macsir wrote:Hi, There
You can't. TM1_API2HAN is ONLY for use with the Excel add-in and piggy-backs off the login that the user has made through the Excel interface. For VB.Net you use the full method for connecting to the server.
kavitha2002
OLAP Product: tm1
Version: 10.3.10100.8
Excel Version: 14
Post by kavitha2002 »
Hi Alan,
I am new to TM1 and IBM cognos.
I am also facing the same issue with "TM1_API2HAN Lib "tm1.xll" not loaded". I am using vb.net project with excel integrated and application starting with tm1p.xla add-in.
Using Tm1 CAM security SSO enabled environment. I want to connect to TM1 perspectives using N_CONNECT_CAM. Previously using N_CONNECT for tm1 IntegratedSecuritymode=1
I have referred the link below from IBM, and converted the vba to vb.net code. So facing the tm1.xll not loaded problem.
http://www-01.ibm.com/support/docview.w ... wg21959177
Is there any other way to open TM1 perspectives from VB.net app. Kindly suggest me. Thanks
