Send mail when submit application in cognos TM1 version 10.2
ChauBSD
Post by ChauBSD »
Hi everyone
I have problem send email when user click submit application approval hierchy. I have one solution is write code TI send mail auto.
I am create cube include dimension (Username, email) . After i am create code TI but i don't know where to start.
I am using cognos TM1 version 10.2 and application web . Can you advise me the solution of this problem ??? I read a lot of thread on this issue but still no viable results. I want to use code TI and how ??
Thanks you so much
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Re: Send mail when submit application in cognos TM1 version
Post by BariAbdul »
sachin
OLAP Product: Transformer,SSAS, EP, TM1
Version: 7.3 2005 10.1 10.1.1
Post by sachin »
ChauBSD wrote: I have problem send email when user click submit application approval hierchy.
Since you are on 10.2, there is functionality to achieve this. Please refer to this link from IBM information center:
http://pic.dhe.ibm.com/infocenter/ctm1/ ... tions.html
We are a version behind and I haven't had a chance to test this yet. However, reading through the section "Configuring HTS" in the above link, it looks like this might help in your situation.
The notification settings display after the list of settings. By default, notifications are configured for the Submit and Reject workflow actions.
ChauBSD
Post by ChauBSD »
Hello eveyone,
I create code TI and send mail Successful.
But when i add process to execute on a workflow action in application the same image under
TestSend mail.png (12.34 KiB) Viewed 10181 times
After then I am deloy application successful but when i click Submit i meet error
Error send mail.png (6.39 KiB) Viewed 10181 times
Why???
ChauBSD
Post by ChauBSD »
Hi all
I have solved the problem. Thank you so much
renken158
Post by renken158 »
dear ChauBSD ,
could you please tell me how did you resolve this? I have the similiar issue, thanks.
TrevorGoss
Version: 10.2.1.1
Excel Version: 14.0.6129.5000
Post by TrevorGoss »
ChauBSD,
did you solve the application web error message by refreshing the application? We kept getting the same issue and we just reset the application and it went away.
renken158,
has your problem been solved yet?
Thanks.
