Arrange the Dimensions in Cube
krithika331
Post by krithika331 »
The arranging of order of the dimensions in the Cube should be from the Less sparse to more dense. The Re-order dimension option in the Cube is different from arranging the Dimensions in the Cube?? When I test the re-ordering of dimensions option I got the percentage as 0 % and when I selected the User option and shuffled the dimensions , I got as 18 % . Does this mean that this changed order is occupying more RAM space and is this suggestible?? I am new to TM1.
Thanks in Advance !!
Re: Arrange the Dimensions in Cube
You want to achieve a NEGATIVE % number as the difference. A positive change indicates the new dimension order arrangement is consuming more memory and is therefore less efficient than the current ordering.
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Post by BariAbdul »
Hi krithika331,You might also find below link useful:
http://publib.boulder.ibm.com/infocente ... 81156.html
