Dear all,
how to calculate the interest rate in tm1? if we use excel, the formula is (=rate(nper,pmt,pv)..
but when i try use this formula in tm1, it cannot..
i have 2 dimensions,(dim a and dim b)
dim a have 4 elements, such as
-present value
-periode
-pmt (use paymt formula)
-rate
and dim b just for write the value..
for the example, i input present value 150.000.000, periode 60, and input the rate 5% manually not using the formula,
and i got the PMT 2.830.685
but how to calculate the rate, if we now the PV, periode and PMT?
what the formula's we use?
please help me..
thanks
Admin Note: Moved to the correct forum. This does not belong in General.
how to calculate interest rate
Re: how to calculate interest rate
You've asked that question in three separate threads now. Once is enough.tm1learn wrote: how to calculate the interest rate in tm1? if we use excel, the formula is (=rate(nper,pmt,pv)..
-present value
-periode
-rate
please help me..
thanks
Also, please refer to the Request For Assistance Guidelines, which ask you to at least do a search of the documentation and the forum before posting a question.
Had you done a search for this, you may well have encountered this thread on that very subject.
tm1learn
- OLAP Product: Tm1
- Version: 10.2
- Excel Version: excel 2010
i'm so sorry for the post
by the way, how to solve this ?
Go to the thread that I provided you with a link to in the previous post. On the last line the words "this thread" are a hyperlink. The method of solving it is contained there.tm1learn wrote:i'm so sorry for the post
