What changes in Models needs Application Re-Deployment
karthik.g
Could anybody please let me know, what all the changes to the models in the architect requires re-deployment of application to tm1 web to make it available for users?
Since it is not clear in the ibm documentation, can anyone please suggest?
- jim wood
- Version: PA 2.0.7
Re: What changes in Models needs Application Re-Deployment
You really need to read the assistance guidlines and give us a lot more details than this. Your post gives everybody only a slight glimpse at what you're trying to do.
mvaspal
- OLAP Product: tm1
- Version: 10 2 2 - 2.0.5
is it Contributor or really TM1 Web?
If contributor, what type of app with what kind of objects (views, websheets), if tm1 web then do you have websheets and/or cube views, do you use the application folder?
karthik.g
ok Jim, i'll give a picture what i'm looking for..jim wood wrote:You really need to read the assistance guidlines and give us a lot more details than this. Your post gives everybody only a slight glimpse at what you're trying to do.
we deployed the applications using performance modeler and every time if we do some changes in the models in architect then we are re-deploying the applications.
Now what i would like to understand is,is there any document which explains us that only these changes to the models needs redeployment of applications?
Any thoughts on this is much helpful..
karthik.g
oops its contributor not tm1 web. we use only views.mvaspal wrote:is it Contributor or really TM1 Web?
nedcpatm1
- Version: 10.1.1
karthik.g
If I understand correctly, you are searching for any TM1 documentation that lists:
(1) activities or tasks (such as grant read access to an element) you perform in Architect that require re-deployment of TM1 Web application in Performance Modeler
(2) activities or tasks you perform in Architect that DO NOT require re-deployment of TM1 Web application (TM1 Web App automatically picks up those changes) in Performance Modeler
Please confirm.
Please confirm.
mvaspal
- OLAP Product: tm1
for example you do not need to re-deploy when you change views or subsets that already exist in the app
karthik.g
Yes. i'm looking for the same.nedcpatm1 wrote:karthik.g
Please confirm.
Natlandry
- OLAP Product: Transformer
- Excel Version: 2008
Did anyone ever reply with a solution to this question?
nedcpatm1
- Version: 10.1.1
I have not seen any documentation on this topic.
Based on my experience thus far, most changes (adding a new element in a deployed view, updating element level security, adding new elements to a subset, adding rights to a node, etc.) won’t require redeployment. If you add a new view to an app, then you have to redeploy the app.
karthik.g
Thanks nedcpatm1nedcpatm1 wrote:I have not seen any documentation on this topic.
