Hey guys, I've got a replication failing in PROD with the error "systemserverclientnotfound".
When I run it manually it replicates fine, but it's running from a chore and started failing a couple weeks ago. "Started" being the key word. The replication ran successfully from the chore many times before this.
Any ideas?
TM1 Replication error: systemserverclientnotfound
tstroumbos
- Excel Version: 2013
- jim wood
- Version: PA 2.0.7
Re: TM1 Replication error: systemserverclientnotfound
Good luck with rep and sync. If you do a search on here you'll find people having al kinds of problems with it. As you may have guessed I'm not a fan of it. I avoid it all costs, something else you'll find as part of the same search.
I have also tried avoid using it where ever I can and I know there are others that feel the same. Is copying data via TI another option?
tstroumbos
I have heard the same thing, but I think we were told the rep and sync issues had been resolved. I guess not!
It's definitely an option, but we're replicating enough (and in PROD) that I had hoped maybe there was a known fix without having to spend hours on creating and testing new code.
- jim wood
- Version: PA 2.0.7
If rep and sync is really your best option then you might want to change your logging level and work with IBM support to see if they can fix the issue,
Jim.
Jim.
