It's a mystery wrapped in a conundrum.
Here are the log entries. You will note the GMT times in the log are 11:51 and 15:27. The server is on Pacific time, GMT-8, so this is happening at 3:51 AM and 7:27 AM respectively. I can tell you that no one is on this system at that time!
9928 [2] INFO 2014-07-08 11:51:19.808 TM1.Cube.Dependency Adding cube dependency: Cube 'P&L' depends on cube '}ElementAttributes_Door'.
9928 [2] INFO 2014-07-08 11:51:19.902 TM1.Cube.Dependency Adding cube dependency: Cube 'New Door' depends on cube '}ElementAttributes_Door'.
9928 [2] INFO 2014-07-08 11:51:19.902 TM1.Cube.Dependency Adding cube dependency: Cube 'New Door' depends on cube 'P&L Allocation'.
9928 [2] INFO 2014-07-08 11:51:19.917 TM1.Cube.Dependency Adding cube dependency: Cube 'P&L Allocation' depends on cube 'Door Detail'.
9928 [2] INFO 2014-07-08 11:51:19.917 TM1.Cube.Dependency Adding cube dependency: Cube 'New Door' depends on cube '}ElementAttributes_Date'.
9928 [2] INFO 2014-07-08 11:51:21.228 TM1.Cube.Dependency Adding cube dependency: Cube 'P&L' depends on cube '}ElementAttributes_Account'.
9928 [2] INFO 2014-07-08 11:51:21.649 TM1.Cube.Dependency Adding cube dependency: Cube 'P&L' depends on cube 'Global Version Control'.
9928 [2] INFO 2014-07-08 15:27:40.437 TM1.Cube.Dependency Adding cube dependency: Cube 'P&L' depends on cube 'FX'.
