Hi...
Is it possible to change subsets dimension when you are using Cognos Insight. I can do it in Web.
In Cognos Insight i have just one option to se all elements, but i can't see all subsets.I can only use subset which is in view.
Thank you.
Regards.
Different subsets in Cognos Insight
- tianoklein
- Excel Version: 2013
Re: Different subsets in Cognos Insight
I have de same issue in my responsibility application.
I'm usig TM1 10.2 and can't select any subset in Cognos Insight.
Someone have any advice?
- Dimension x Subset
- Problem.png (4.96 KiB) Viewed 2626 times
