Trying to export a 2-dimensional cube to a txt file where the order of elements is important in one of the dimensions.
So I create the static subset with the correct order (also tried with dynamic) and assign it to the source cube view.
When I open it from cube viewer it looks fine but when the TI uses it as a view extract it seems that the subset get automatically reordered to the original dimension order.
Any idea?
CX 10.2.1
Matyas
View extract - incorrect sort order when exporting
Re: View extract - incorrect sort order when exporting
This is the expected behavior for the export function. Disappointing but that's the way it is. If you need the data in a certain order you'll either have to sort the file yourself after the fact or do your own walk through the subsets in the Prolog tab using CellGetN and ASCIIOutputs inside WHILE loops.
- OLAP Product: tm1
- Version: 10 2 2 - 2.0.5
Actually your idea can work for me as we are talking about a simple attribute cube, only 2 dims, so thanks very much for this!
I think it is not the export function but how TM1 handles the view extract. I presume if I was loading from one cube to the another, the same would happen.
Surely not what I would expectThis is the expected behavior for the export function
- Version: PAL 2.0.9.18
Indeed, expected behavior and how TM1 handles things internally.
For an article on exactly the same topic (you were not the first to ask this question), see on my site an article from October 2011: Sorting TM1 text output
( http://users.skynet.be/fa436118/wim/tm1 ... ort_EN.htm )
IBM Champion 2024
IBM Champion 2024
- OLAP Product: tm1
thanks a million Wim, I have been lucky enough not to hit into this until now
