Deleting control object
Posted: Thu Jun 26, 2014 10:51 am
by deepakjain2020
When we create a pick list for cube it will be generated as a contol cube.
We can remove }cube_name.cub from Data Directory to delete that.
Is there any other way for deleting control object?
Deepak Jain
Re: Deleting control object
Posted: Thu Jun 26, 2014 10:54 am
by Alan Kirk
You can delete control cubes through TI. I've done that in the past when an element security cube was incorrectly created. It doesn't require a reboot the way that that deleting from the data directory does.
But of course... proceed with extreme caution.
Posted: Thu Jun 26, 2014 11:05 am
by deepakjain2020
Hi Alan,
So using the function
CubeDestroy(}cube_name) will delete only specific cube, right?
What are other things we need to take care off as part of caution?
Deepak Jain
Posted: Thu Jun 26, 2014 11:13 am
by Alan Kirk
One would certainly hope so, for it would be the mother of all bugs if it didn't.
Mostly:
(a) That the cube name that you type as an argument to CubeDestroy() is the intended one;
(b) That it's a control cube that you genuinely intend to destroy;
(c) That you fully understand what the control cube is doing, why it needs to be destroyed, and what the consequences of that destruction will be.
Fail in any of these three, and the deletion of any system object can cause your entire day to take on a rather bleak aspect complete with hair pulling, wailing and the gnashing of teeth.
Posted: Thu Jun 26, 2014 11:20 am
by deepakjain2020
Thanks Alan
One more question, Why the delete option is disabled for control objects any idea?
Is it because those are the auto-generated?
Deepak Jain
Posted: Thu Jun 26, 2014 11:36 am
by Alan Kirk
At a guess it's just a safety precaution and a discouragement to do it. If they could be deleted by the GUI it would be too easy for a novice admin to delete a system object thinking that it served no purpose, only to find out that they were wrong about that. (Say, blowing away an attribute cube and not realising that a previous admin was using one of the attributes in some rules.) On the other hand if you go to the effort of deleting a system object through TI or through removing the object from the data directory, it's generally going to have been given a bit of thought. I think it's really more intended to be a warning than a barrier.
