[TM1Web] Relative Proportional Spread
Rosanero4Ever
Version: 10.1.1
Post by Rosanero4Ever »
on Cognos Express 10.2, using TM1Web, I can't spread data using the relative proportional method referring to another cube.
Please, see the attached images
In the second image only a cube is listed in the dropdown list
But, using Architect, I can perform a relative proportional data spreading referring to another cube data
Do you know the reason of this different behavior?
Thank you so much for your posts.
Re: [TM1Web] Relative Proportional Spread
This is a documented bug in 10.2.0 and 10.2.1. You need to either apply the latest fix pack or upgrade to 10.2.2.
Just noticed you said it was Cognos Express not enterprise TM1. In which case you might be stuck downloading a fix pack and CX 10.2.2 hasn't been released yet.
Rosanero4Ever
Version: 10.1.1
Many thanks!!
