Very simple Q, BottomCount doesn't work?
macsir
Version: PAL 2.0.9
Post by macsir »
In a cube view with single row, BottomCount doesn't work as expected? Other options are working fine.
Accdording to Manual, BottomCount is Filters the view to display only the smallest n elements, where n is a number specified in the Value option. Whatever value is set, the final view result is always empty?
Can anyone test it as well? My version is 10.1.1, Thanks. :?
macsir
Version: PAL 2.0.9
Re: Very simple Q, BottomCount doesn't work?
Post by macsir »
Can anyone have a try?
macsir
Version: PAL 2.0.9
Post by macsir »
Got answer by myself. Actually this function works for all elements in that single row even if you suppress zeros. It is comparing all elements in that dimension to get the smallest ones. :mrgreen:
