TM1 Web Vs TM1 Contributor (Performance)?
Posted: Mon Jun 16, 2014 8:11 pm
Hello All
I want your experience input on
Is there any performance difference between TM1 Web and TM1 Contributor conceptually? If so, what could be the conceptual factors affecting this ?
Reason to raise this question:
I went to many post as well as i tried experiment on this. I tried out to find the difference between two. In TM1 Web, once we input the data it turns in to green and in to black thereafter. It doesn't turn in to blue so it saves time over there.
In my test to input data at consolidation in TM1 contributor takes average 4 seconds to update one cell due to big approval hierarchy. To update input data in a cell at leaf level takes less than a second.
While in the TM1 Web, when i entered input data , it takes average 1.5 seconds to update one cell with same approval hierarchy. To update input data in a cell at leaf level takes less than 0.600 micro second.
In short i saw, increase in performance at least by 50 %
I am appreciating your inputs,efforts and time would spend behind it.
Thank You
Dharav Patel
Thank You
Dharav Patel
