Hi All ,
I have the Scheduled TI process to load data from SAP to TM1 which gives me the error message as Execution was aborted. No Security Access for "SetElementGroupsSecurity".
But if the same TI executed manually it get executed successfully .
So please help me on this issue as i want to automate this process.
Vaibhav Late
"SetElementGroupsSecurity" error while loading data from SAP
late.vaibhav
- OLAP Product: tm1
- Version: 9.5.2, 10.2.2
- Excel Version: 2007 2010
- jim wood
- Version: PA 2.0.7
Re: "SetElementGroupsSecurity" error while loading data from
Topic moved as it was posted in the wrong forum.
- Which users are executing the TI?
- Do you allow the process "Security access"?
late.vaibhav
- OLAP Product: tm1
I am Using Admin ID for this process an All user in the server has access to this process.
To elaborate on Wim's point as I am convinced it is exactly your issue and you have missed it.late.vaibhav wrote:I am Using Admin ID for this process an All user in the server has access to this process.
He was not referring to a user having access to run a process but rather the fact that since version 9.4 (and unusually well documented) if you are modifying security in a TI initiated by non-admin users or a chore... you need to right click on the TI process and select the security access button. The option will then be ticked and standard users access gets temporarily elevated while running it.
