Contributor Accessing a view, creates private view automatic
Posted: Mon Jun 09, 2014 7:00 pm
by dharav
Hello All
Contributor Accessing a view, creates private view automatic. Could you please throw light on its occurance?
Whenever, user accessing view for their region, there is automatic generation of private view look like below.
(Private view) ABC_{6abca9be-1c55-4bd1-b795-dff5ae8379ab}_[}tp_tasks}{6abca9be-1c55-4bd1-b795-dff5ae8379ab}].[69999901]
This view disable the user to export the view from contributor either as a slice or a snapshot. It throws the error from excel:" The name of the file is too long". I have to go to individual users folder in data directory and delete all private view created under their folder with .vue...As soon as i delete those, they are able to export the view from contributor as a slice or as a contributor.
I want to know the conceptual reason behind it. I just tried to set the Maximumviewsize parameter = 750 on 64bit (It wasn't there earlier in the configuration file (TM1S.CFG)).
I would be eager to know your input on this.
Thank You
Dharav
