As I know, Linux supports the installation of TM1 Server and the TM1 instances.
My Windows TM1 Client could connect to the Linux TM1 Server.
May I know how to setup the TM1 Web and Performance Modeler?
Linux TM1 Server and TM1 Web
- jim wood
- Version: PA 2.0.7
Re: Linux TM1 Server and TM1 Web
Not sure about 10. as it's gone all java on us, but below that you needs a seperate windows server for both.
- Version: 10.1.0
Yes, I've prepared a Windows Server.jim wood wrote:Not sure about 10. as it's gone all java on us, but below that you needs a seperate windows server for both.
May I know how to make the connection?
- jim wood
- Version: PA 2.0.7
Within Web you need change the admin host that it points to. You can do this once it's logged in but you can also set a default in the web config fie. As for Performance Muddler, I would guess it's similar but I've never tried it. Normally this kind of detail is covered in the install guide but I wouldn't be surprised if it isn't.
