Formatting Active Forms in TM1Web
Posted: Sat May 24, 2014 8:27 pm
by Willi
I use TM1 10.2 FP1 with Excel 2010. I generate an active form from a Cubeview and populate it to TM1Web. The data is shown correct but the colours of the consolidated rows are wrong. One data-line (N-Element) is coloured like a consolidated ro and all other lines (including all consolidated rows regardless the Level) has no colour at all. changed nothig from the generated Schema.
Any hints how I get the correct colurs?
Thx and regards.
Re: Formatting Active Forms in TM1Web
Posted: Sat May 24, 2014 9:00 pm
by Gabor
I know there was a bug with FP1, depending on the structure of the Active Form, so in some cases it was working and sometimes it mixed the colors or didn't even show them.
As far as I remember it was not addressed between IF1-IF3, I think I did not recheck IF4.
I would simply go and try, if it is solved with the recent 10.2.2 release, which should contain all hotsite fixes after FP1.
Having these fixes in is a must anyway, otherwise there are too many things, which do not work as expected.
Posted: Sat May 24, 2014 9:47 pm
by Willi
Thx for the reply. Do you have a slight idea wich structure is okay and wich not?
Posted: Mon May 26, 2014 8:42 am
by Gabor
No, I am sorry.
Posted: Mon May 26, 2014 7:28 pm
by Willi
No Problem at all. But I had to ask ;)
