I am trying to build a drill down report in report studio using TM1 as the datasouce, however I have noticed that the default behaviour
when clicking a parent node returns the chilren of that node but not the parent that was clicked on in the first place.
I would like the report to more or less perform similiar to active report in tm1 whereby you drill parent member and it returns
its chilren directly underneath keeping the parent member displayed as well.
Is there a technique whereby you can retain members that are being drilled on ie parent node and also display the chilren returned
underneath as well??
Zark
drillup / drilldown behaviour - Report Studio
mvaspal
- OLAP Product: tm1
- Version: 10 2 2 - 2.0.5
Re: drillup / drilldown behaviour - Report Studio
In business insight advanced you can right-click the parent element and select Expand Member, if I remember well. Report Studio should be similar to this.
