hello everyone
please explain to me why we can not use the ATTRN in the link for another cube, for example:
= N: IF ( ATTRN('Dim_X',!Dim_X,'Num') = ATTRN ( 'Dim_Y', !Dim_Y, 'Num1'),
DB('Cube1',!Dim1, Dim2, ATTRN('Dim3',!Dim3,'Num')), DB('Cube2',!Dim4, Dim5, ATTRN('Dim6',!Dim6,'Num'));
gives an error when I save
thank you
ATTRN in other cube
Re: ATTRN in other cube
It's failing because attrn() returns a number and dimension references need to be strings.
Wirt
- Excel Version: 10
You mean that if in the link is present ATTRN, all elements of dim. should be string?
What he is telling you is that the DB function requires strings for all its arguments and you are using ATTRN as some of those arguments and that function returns numbers. Convert them to string using the STR function.
- jim wood
- Version: PA 2.0.7
Wirt,
Think about it. If you build a TI all the element variables have to be string. You may able to store numbers against them but all element names are strings, how else would you mix numbers and text so freely when creating elements?
Jim.
Jim.
