Feeders knowledge
deepakjain2020
Version: 9.5.2; 10.2.2
Feeders knowledge
Post by deepakjain2020 »
Cube1:
It has 4 dimensions.
1. City
2. Measure
3.Account
4. Version
Cube2:
1. States
2. Measure
3. Account
4. Version
City Dimension in Cube1 is having states name at consolidated level.
Cube1 gets data from cube2 based on rules written. Cube 2 is feeding cube1.
For few of the elements in cube1 when I right click on cell and select check feeders, it was showing as not fed. Due to which the consolidated element was having a value as 'ZERO'.
There were no changes made to rules in any of the cubes. I have saved the rules of Cube2 and after that the data was fed to Cube1 properly.
Does saving of rules will create a feeder file again?
I am not sure whether the issue was due to feeders file or what could be other options?
Please share your opinions on what could be reasons.
Deepak Jain
EvgenyT
Version: PAL 2.0.8
Re: Feeders knowledge
Post by EvgenyT »
You can start by posting rule and feeder
deepakjain2020
Thanks for reply :)
I will like to know whether the feeders (or) rule files get corrupted? If yes, what could be possible reasons?
I will try to create appropriate rules and feeders based on scenario and post it soon.
Deepak Jain
Version: PA 2.0.7
Post by jim wood »
Rules are attached to the cube itself just in case the rule file goes missing or gets corrputed so I doubt that's your issue, but without seeing what your talking about (as mentioned by EvengyT) we won't be able to help you further.
