I'm trying to use the TM1 Java API and right from the start I'm facing an issue.
The sample code I'm trying to run is quite simple but I'm getting an error on the following line :
TM1Server server = tm1bean.openConnection(serverName, userID, password);Code: Select all
java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.security.ssl.SSLSocketImpl.connect(Unknown Source)
at sun.security.ssl.SSLSocketImpl.<init>(Unknown Source)
at sun.security.ssl.SSLSocketFactoryImpl.createSocket(Unknown Source)
at com.applix.tm1.TM1NetClass.ConnectToHost(TM1NetClass.java:215)
at com.applix.tm1.TM1NetClass.ConnectUsingIPv6(TM1NetClass.java:199)
at com.applix.tm1.TM1NetClass.Connect(TM1NetClass.java:165)
at com.applix.tm1.TM1Bean.getAdmEntryList(TM1Bean.java:460)
at com.applix.tm1.TM1Bean.getNumberOfServers(TM1Bean.java:290)
at com.applix.tm1.TM1Bean.findEntryByServerName(TM1Bean.java:550)
at com.applix.tm1.TM1Bean.openConnection(TM1Bean.java:141)
at HelloWorld.main(HelloWorld.java:28)
I've already followed IBM advices adding applixca.pem to the keystore and using dedicated parameters (-Djavax.net.ssl.trustStore="C:/Program Files/ibm/cognos/tm1/bin/ssl/tm1store" -Djavax.net.ssl.trustStorePassword=applix) for Eclipse.
Any idea is welcome.
Bob
