Attributes updation issue
Posted: Fri May 02, 2014 12:30 pm
TM1 Version 10.2.
In defining of the Rule calculation, I have factor which involved in the ratio calculation. I have the time dimension which is at both the month level and week level and the factor is derived as (X/Weeknumber for Weekdates, Y/Monthnumber for dates under month hierarchy). The factor is defined as the text attribute in time dimension. How can I derive the factor both at Week. month level. Week no, Month No are comming the database. Can we calculate the factor at SQL level/Rule Level and use it as an attribute. Any ideas??
Thanks in Advance.
Thanks in Advance.
