Tm1 user submitting data through Architect
Posted: Wed Apr 30, 2014 4:09 pm
Hi, I hope someone can offer some advice. We are working with Tm1 9.5.2.
A user is going into a cube and amending dates that effect calculations (driven by rules) in a cube view through Architect. This in real time through rules effects data in other cubes. A TI processes runs off these cubes to consolidate the data on demand. I can see in the transaction logs that the user amended the data at 11am this morning and the consolidation process was run at 1pm, with no error. However some of the data that has recalculated was not consolidated (I cant prove it was calculated at 1pm but can see the user made the amendment at 11am). I have re run the process and it worked without changing any data.
There has been a number of issues like this, and I am wondering if there may be a problem with the way the user is entering the data on their laptop and it submitting to the server to recalculate. Would the transaction log, record an entry even if the user does not recalculate/submit after entry?
Can anyone recommend any solutions or ways to investigate this? At the moment I am considering exporting data to text file every 10 mins from the calculation cube (Theres only 2000 rows and 2 columns required), as I suspect the data was not properly submitted and I would like to know the time the calculations changed.
