TM1 Login with Cognos Express
Posted: Fri Apr 25, 2014 11:35 am
by stefan1168
I've installed on a Windows 2008 R2 Standard Server System Cognos Express 10.2.1 with FP1. After the installation was complette I installed the xCelerator function. After that the TM1 Store CXMD was installed. I read the installation dokument an so I login to http://myserver:19300/pmhub/pm/admin to the Store Configuration. Like the description I take action on the
com.ibm.ba.pm.opsconsole.monitor.tm1.TM1OpsConsoleMonitor.dictionary
entry. So I've changed the DefaultGroup to CAMID(":EXPRESS-ADMINISTRATOREN") (for a german installation) and the DefaultServer to CXMD
After that I want to login to http://myserver:19300/pmhub/pm/opsconsole/userscreen.vm
It appears the login screen.
So want to login with:
Admin-Host: localhost
Servername: CXMD
(Group) Gruppe: CAMID(":EXPRESS-ADMINISTRATOREN")
(Username) Benutzername: CognosExpress\administrator
(Passwort) Kennwort: ExpressPassword
But I can't login. I get the following error message: "Die angegebene Gruppe ist auf dem Server nicht vorhanden." (The named group does not exists on the server.)
I search in the internet for this problem but I found no hints for that. Any ideas ?
Best regards
Stefan
Re: TM1 Login with Cognos Express
Posted: Fri Apr 25, 2014 1:10 pm
by moby91
The german error message
"Die angegebene Gruppe ist auf dem Server nicht vorhanden"
returned by Operations Console is the german translation of the english error message
"The specified group does not exist on the server"
As you received that error message, what happens when you apply the IBM Technote 1620207 ?
http://www-01.ibm.com/support/docview.w ... wg21620207
Unable to log in to Operations Console - may get two different errors.
Technote (troubleshooting)
Problem(Abstract)
A user attempting to log in to the TM1 Operations Console may encounter errors.
Symptom
"An error occured in authentication"
or
