I have turbointegrator process, and it is lunched from web sheet. Parameters to process gets from cells, how to avoid putting enter sing from user (trim?)?
Turbointegrator string parameter - trim enter
Re: Turbointegrator string parameter - trim enter
It's not clear what you're asking here.Motyl wrote:Hi
"Trim" usually refers to removing leading and trailing spaces from a string (and there is a rules function that you can use in TI to do that), but "avoid putting enter sing from user" is something that I can't reconcile with that.
Could you please clarify your question.
iansdigby
- Version: 9 + 10 + Plan An
- Excel Version: All
I'm guessing the enquirer means how to remove the "Enter String" or carriage return character - ASCII code 13, from a passed parameter.
In theory, a string that contained a carriage return could be cleansed in TI with something like:
DELET( pString, SCAN( CHAR(13), pString), 1);
I haven't tried it though....
I thought of that, but unlike an end of line in Word you aren't likely to find a carriage return at the end of a cell input. (In any case that's usually a CR/LF combination in Word.) Excel does use LF characters (ASCII 10, as opposed to CR ones) to separate lines in a multi-line text entry, but I'm not sure why something like that would (or should) need to be passed as a process parameter. In any case you need to work at doing that in Excel; you only get the LF character if you press [Alt]+[Enter], or if you manually add the character on via an CHAR() function. (Or possibly one other way that's on the tip of my brain but which I can't think of at the moment.) You only get a CR if you do the latter of those.iansdigby wrote:I'm guessing the enquirer means how to remove the "Enter String" or carriage return character - ASCII code 13, from a passed parameter.
The question remains a mystery.
