TM1 v 10.1.1 - Microsoft Visual Basic Error Msg
Posted: Wed Apr 16, 2014 5:21 pm
by jadawson50
I have install IBM Cognos TM1 version 10.1.1 client locally on a Laptop with Windows 7 Pro (32bit O/S, 4GB ram, 500GB HDD, Office 2007 with SP3, local user account is part of the Administrator Group) when I launch IBm Cognos Perspective application I get the following error msg within Excel 2007. ( I have uninstalled, re-installed the TM1 Client v10.1.1 again, same issue)
"System Error &H80040411 (-2147221231) Classfactory cannot supply requested Class" then I press the ok button, then get the next following error message "Out of Memory" has any seen this before ? and is there any resolution for the error messages.
I tried install the TM1 v10.1.1 on a Windows XP desktop and received the same error message.
Note: I did get it to install on another Windows 7 pro laptop and prespective worked like a charm, but then any other installations i have completed and run the Perspective application, i get the above two error messagaes in Excel 2007.
thanks
John
Re: TM1 v 10.1.1 - Microsoft Visual Basic Error Msg
Posted: Wed Apr 16, 2014 5:25 pm
by declanr
Posted: Wed Apr 23, 2014 1:45 pm
by jadawson50
That didn't work, still getting the same error message. Only thing left to do, is backup up all the users data and reformat the user laptop and re-install everything. I don't want to do that if possible.
