TI Process: Unable to open data source
Radhika
OLAP Product: IBM Cognos TM1
Version: v9.4.1
Excel Version: Microsoft Excel 2003
Post by Radhika »
Hello All,
I have created a TI process to build a dimension from a CSV file, the source path for this file is stored in a cube of TM1. I have created a parameter in Prolog tab to store the path of this file, when I run the TI process it throws an error unable to open data source. I tried the below options
Created a new TI job - not working
Running TM1 Service under service account which has admin access.
Able to access the path of the source files from command prompt.
Please help me to resolve the issue
Radhika
Re: TI Process: Unable to open data source
You are sure that you don't have a typo... We've all encountered this type of human errors in the past.
Did you do a AsciiOutput to guarantee the validity of the file path and filename?
Is the CSV file closed?
In addition to what Wim said, is the CSV file on a local drive, or on a network share?
If it's on a network share then the fact that the account that you're using to run the server has local Admin rights is irrelevant; it would also need to have permissions to access that share. Similarly this would raise the question of whether you did the command prompt check on the server box that TM1 is running on, using the account that the TM1 server is running under. If you did it on your local machine, that doesn't guarantee anything. Remember that in checking access you need to look at everything from the server's point of view, not your own.
macsir
Version: PAL 2.0.9
Post by macsir »
Maybe a snapshot from your TI interface can tell us.
Radhika
Version: v9.4.1
Post by Radhika »
Thank you all for your response.
@Wim, ASCII output gives me the exact file path.
@Alan, I have the CSV file on my local machine.
Here I have attached the screen shot of the Path, System Info Cube and the script in the metadata tab.
Radhika
Error.docx
(121.22 KiB) Downloaded 762 times
Radhika wrote:@Alan, I have the CSV file on my local machine.
Well, unless the TM1 server is also running on your local machine how do you suppose it's going to access the file? D:\GL Source Files sounds like a local drive letter. Is that the D: drive on the TM1 server, your local machine, or both?
macsir
Version: PAL 2.0.9
Post by macsir »
Radhika
Version: v9.4.1
Post by Radhika »
@tomok, both d rive and TM1 server are on my local machine.
macsir
Version: PAL 2.0.9
Post by macsir »
Try this in your Prolog,
Datasourcenameforserver = cImportFile;
Radhika wrote:@tomok, both d rive and TM1 server are on my local machine.
I think that this comes back to Wim's original question about whether you're certain that the file is closed. You'll get that error if you still have the file open in an application whuch has a lock on it, like Excel.
macsir
Version: PAL 2.0.9
Post by macsir »
No, Alan. The problem in his code is that he assigned PATH rather than FILE to datasourcenameforserver in his prolog. ;)
Quite right; I didn't look at his Word attachment before but the mistake is visible in there.
