The overnight process is scheduled daily and has the structure:
Start Maintenance
Load MetaData
Update Subsets
Stop Maintenance
Load Landing Data
Load Cube Data
Finish
The Start Maintenance part of the process only has one function, it enables BulkLoadMode with the command
EnableBulkLoadMode() ;
Problem Definition
For the second time in a week, when the overnight process was scheduled and the chore was run, the start maintenance process would start, but would not finish processing the TI process that enabled the bulk load:
The system has entered bulk load mode as can be seen through Ops Console and if you try to connect to the instance through Architect, you get the error ‘ServerInBulkMode’.6364 [] INFO 2014-04-10 07:00:14.200 TM1.Chore Chore "OVERNIGHT" executed by scheduler
6364 [] INFO 2014-04-10 07:00:14.200 TM1.Process Process sys - Start Maintenance executed by chore OVERNIGHT
Server Restarted
6572 [] INFO 2014-04-10 19:01:09.242 TM1.Server Closing...
6572 [] INFO 2014-04-10 19:01:09.242 TM1.Server Saving...
6572 [] INFO 2014-04-10 19:01:09.242 TM1.Server The server is coming down...
The only way to get the system back is to kill the process and restart.
When the process runs successfully it can be seen in the tm1server.log that the next phase of the overnight chore has executed:
The TM1 model code had not changed between these two runs and as can be seen, they were scheduled to run at the same time.2360 [] INFO 2014-04-08 07:00:06.323 TM1.Chore Chore "OVERNIGHT" executed by scheduler
2360 [] INFO 2014-04-08 07:00:06.323 TM1.Process Process sys - Start Maintenance executed by chore OVERNIGHT
2360 [] INFO 2014-04-08 07:00:11.081 TM1.Process Process "sys - Start Maintenance": finished executing normally, elapsed time 4.76 seconds
2360 [] INFO 2014-04-08 07:00:11.081 TM1.Process Process Dimension Load executed by chore OVERNIGHT
2360 [] INFO 2014-04-08 07:00:11.081 TM1.Process Process "Project 1 Dimension Load" run from process "Dimension Load" by user "R*OVERNIGHT"
There are no additional details in the tm1server.log.
EnableBulkLoadMode() ; Does not work reliably, causing the system to hang and require a service restart
TM1 Build Number: 10.1.10000.26473 (No FixPacks......)
Windows Server 2008 R2
I saw that the same problem was high lighted here http://www.tm1forum.com/viewtopic.php?p=14838 but this link relates to 9.4.1 (FP3) David said that he thought bulk load mode was being depreciated from 9.5.2, but it's still here in 10.1 has anyone else found similar issues using BulkLoadMode in 10.1 or beyond?
