Dear all,
I get an error message in TM1 Web 10.2 (latest fixpack) if I click in an input cell or try to copy a value in.
--- "nodeType" is null or not an object ---
I have to use Internet Explorer 8 maybe thats the cause.
It happens only in some of the cells on the websheet.
Its an ordinary cell with a DBRW in it.
any ideas?
Michael
Error message in TM1 WEB 10.2
Re: Error message in TM1 WEB 10.2
mykill wrote:Dear all,
any ideas?
Michael
There's nothing "weird" with that cell? Try limiting the websheet to only that cell and test again.
Also, remove all formatting from the cell. Does the problem persist?
Inspect the element references. For example, can you use a DBRW formula to almost exactly the same cube reference but changing 1 cell reference? (another month, cost center, account, ...)
mykill
- Version: 10.2
Found the issue.
If you copy a value in, the cursor will jump some cells to the right. Is this cell a hidden cell, the error message is triggert.
Gabor
- Version: [2.x ...] 11.x / PAL 2.1.13
- Excel Version: Excel 2016-2021-365
Are you really sure, you have the latest build 40681 (FP1 IF3). I cannot see the cursur move while copying data.
At least IF1(new) build 40547 is a must for a non-english (german) environment.
mvaspal
- OLAP Product: tm1
- Version: 10 2 2 - 2.0.5
Good to know, a similar error message appears in 10.2 Contributor if the user group does not have the proper data reservation capability assignments
Hi,Gabor wrote:Are you really sure, you have the latest build 40681 (FP1 IF3). I cannot see the cursur move while copying data.
Bolded and underlined in the quote above. Do you mean that there is a new interim fix for TM1 10.2?
Gabor
Yes, I do. It addresses a whole bunch of issues, especially for Web, like PI08769 View Formatting lost when a saved view is changed in TM1Web.
Unfortunately residing in "a private section of IBM Fix Central", so you need to involve support to get your ID granted access.
Thank you for the information Gabor.
mykill
- Version: 10.2
IF 3 will solve the issue.
many thanks Gabor.
regards
Michael
many thanks Gabor.
regards
Michael
