I need some assistance with an issue we are experiencing on an ODBC connection on a Windows Server 2008 Enterprise 64-bit box. I have updated the TNSNAMES.ORA file to include the new data source in the correct location and have created a new system DSN. When I test the connection via the ODBC Data Source Adminstrator, it returns as "Connection successful".
However, when I try to connect via TM1 (TI Process), the connection fails with the following messagebox text:
"Unable to Open Connection to Database."
There is also the following error reported in the log files:
9132 [dc] INFO 2014-04-01 10:40:01.703 TM1.SQLAPI Driver supports SQLFetchScroll
1000 [e7] ERROR 2014-04-01 11:13:20.999 TM1.SQLAPI 08004[Oracle][ODBC][Ora]ORA-12154: TNS:could not resolve the connect identifier specified
1000 [e7] ERROR 2014-04-01 11:13:20.999 TM1.SQLAPI E16) Cannot connect to ODBC data source "XXX" 08004[Oracle][ODBC][Ora]ORA-12154: TNS:could not resolve the connect identifier specified
1000 [e7] ERROR 2014-04-01 11:13:20.999 TM1.SQLAPI 08003[Microsoft][ODBC Driver Manager] Connection not open
I am using 64-bit ODBC drivers and a 64-bit TM1 server, version 10.2.00100.39992. TNSPing is fine and I can also SELECT * FROM DUAL fine using SQLPlus on the server.
The service is running as a local account.
Any help greatly appreciated.
Dan
