security process end-user use process
ChauBSD
Post by ChauBSD »
I have process "copy data". When I login admin user , i run process successful.
But i login end user , after i run process "copy data" , i get the message "process fail". I security process for end-user "READ".
Why??? I security process for end user.
Thanks all
babytiger
Re: security process end-user use process
Post by babytiger »
Can I assume you are trying to update a security cube using a process?
If so, select security access for your process. You can do that by right click on your process, and select "Security Access".
Hope it helps.
MK
