When the process is executed by myself using tm1 web , it takes less than 10 seconds. When the same process is executed by other user, it takes around 2 minutes and some time "Operation failed" message is received.
The process runs in background and gets executed.
I searched a lot in Google but was not able to anything concrete. Can you please throw some light on the reason behind it.
Vinay
TM1 process
Re: TM1 process
Would need to see the code or at least know what its doing as per the request for assistance guidelines.
Re: TM1 process
The code copies the value from one intersection to another intersection.
- qml
- Excel Version: 2007 - 2016
Re: TM1 process
I'm afraid you'll get the same result here if you refuse to follow the guidelines and to provide all the concrete details.vins wrote:I searched a lot in Google but was not able to anything concrete.
Kamil Arendt
