Getting error while loading string measure element
gandikota
OLAP Product: Cognos TM1,Cognos Reporting
Excel Version: 10.2
Post by gandikota »
When i am trying to archive source cube data to target cube, i am facing error for only string measure element and for other elements, the data got loaded successfully.The error info is : Data Source line (2) Error: Data procedure line (0): Cannot convert field number 6, value "No Comments" to a real number.
In my TI Code, i am creating temporary view for source cube which acts as my data source by passing parameters and filtering the view(Bedrock Cubeview create process) .The issue is arising for only string measure elements.
Can any one suggest on the above issue.
EvgenyT
Version: PAL 2.0.8
Re: Getting error while loading string measure element
Post by EvgenyT »
You are trying to load string to a numeric cell, hence the error.
Can you please provide the code
Evgeny
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Post by Michel Zijlema »
EvgenyT wrote:You are trying to load string to a numeric cell, hence the error.
More specifically the issue is that you have the data variable in your variables tab set up as numeric, while the value you're receiving is string (in some cases). If the value can be either string or numeric it's better to setup the variable in TI as string and convert the value to numeric when you're loading a N-cell.
Michel
As what Michel stated I have a few stock TIs that move all the data out of a cube or into a cube and set the variable as a string then just use:
sMeasureType = DType ( sDimMeasures, v5 );
If ( sMeasureType @= 'S' );
           CellPutS ( value, sCubDest, v1, v2, v3, v4, v5 );
ElseIf ( sMeasureType @= 'N' );
           nValue = StringToNumber ( Value );
           CellPutN ( nValue, sCubDest, v1, v2, v3, v4, v5 );
EndIf;
The above assumes that v5 variable equates to the measures dimension.
EvgenyT
Version: PAL 2.0.8
Post by EvgenyT »
Thanks for elaborating further guys.
Since your datasource is a view you can also take advantage of Value_is_String function.
Like Rodger said, set variable to string and use this bit below
IF(VALUE_IS_STRING=1);
CELLPUTS(sValue, vCube,vElem,vElem2....)
ELSE;
CELLPUTN(nValue,vCube,vElem,vElem2....)
ENDIF;
Evgeny
gandikota
Excel Version: 10.2
Post by gandikota »
Thanks for the replies.
I already declared as a string in variables tab. And my measure string element is of string type in both source and target dimensions.I am getting the same error.
Here i am using cellgets and cellputs functions for fetcing and loading respectively.
Michel Zijlema
gandikota wrote:Hi All,
Could you please post a screenshot of your Variables tab?
Michel
gandikota wrote:I already declared as a string in variables tab. And my measure string element is of string type in both source and target dimensions.I am getting the same error.
You are aware, though, that it doesn't matter what data type you have the elements declared as unless they're in the last dimension in both cubes, right?
Because the only way you're getting the error that you described is if, in some way or another, you are trying to fit a round (string) peg into a square (numeric) hole.
It might be worth describing the dimensionality of the two cubes as well.
EvgenyT
Version: PAL 2.0.8
Post by EvgenyT »
Given what Alan said about dimensionality and using examples myself and others provided you should not get an error. Is your last dimension a measure dimension with elements like value, string etc?
Slightly off the topic here: using CellGets and CellPuts in this context will concatenate strings in the cell, is it what are you really after?
Evgeny
