I want know the correct method to pass the parameter to vbScript,Currently i am using following code to send parameter to .vbs file which is created to sent mail.
arguments = 'CScript D:\Mail\SendMailOther.vbs '|sSMTPSvr |' ' | sSender | ' "'|pRecipient|'" "'|pSubject|'" "'| pBody | '"' ;
EXECUTECOMMAND(arguments ,1);
When i rum the vbs file after hard-coding the parameters it works but when i try to send the parameters from TI it doesn't give any error message but my mail is not get triggered.
I am using following code in my Vb Script:
SMTPServer = WScript.Arguments(0)
Mail_from = WScript.Arguments(1)
Thanks & Regards
Vaibhav Late.
Running VBScript from tm1
late.vaibhav
- OLAP Product: tm1
- Version: 9.5.2, 10.2.2
- Excel Version: 2007 2010
babytiger
- OLAP Product: Cognos TM1, EP, Analyst
- Excel Version: 2013
Re: Running VBScript from tm1
TI wouldn't give out any error message, since the command executed is a correct syntax vbs command.
I would suggest test out the command from a command line, run cmd, and enter >D:\Mail\SendMailOther.vbs with parameters between double-quotes. If there's anything wrong with the vbs, you will get an error.
MK
