the manager want to freeze the data in order to avoid any data change while he is reading the report.
how can it be done ? TM1 workflow ?
How to Freeze data ?
Re: How to Freeze data ?
Open the Subset Editor for the relevant Scenario dimension, right click on the relevant element and select Security\Lock.
Just select Unlock to reset later.
Tom
Tom
pobrouwers
- Version: 9.5.2
- Excel Version: 2003-2007
Is it possible to do this by TI ?
Thx
Thx
I think the nearest you'll get is ElementSecurityPut which means you will need to have a statement for each security group or loop through them.
HTH.
Tom
HTH.
Tom
The other classic "TM1 method" of tackling this problem would be to copy the data to an alternate "reporting" version/scenario which users only have READ access to as opposed to the planning/forecast version and run the relevant reports off that.
Depending on the need the copy could be automated nightly/weekly whatever or could be triggered in specific cases from an action button for given views or slices of cube data.
- Steve Rowe
You need to make sure you understand what the manager means by "Freeze".
Sometimes it just that the base numbers should not ever change which is do-able with security.
A harder problem is that reported consolidation values should not change either. i.e. What happens if an account is moved from one total to another. TM1s dynamic recalc can be a bit of a curse in "hard-core" financial accounting type application, though there are workarounds.
Anyway try not to offer the second option as it's a significant piece of work to set it up.
