I am exporting a TM1 cube using asciioutput function. Say I have 5 dimensions, I was able to export these 5 dimension into records (Each dimension one instance of an element) in text or CSV file. One of the dimension is measures where elements will be assgined values. Now When I export only one element of the measures dimension is shown up in a record. In another words one element for each record.
How do I export where all the elements of measures dimension can be shown in one record?
Shown here how it should appear
Dim A Dim B Dim C Dim D Dim Measures Element 1, Dim Measures Element 2, Dim Measures Element 3
Customer Year Month State 1000 25.5 30
Another way to describe is how to move the measures elements as header of the file and aslo show the values?
Currently it is showing up like this
Customer Year Month State Dim Measures Element 1 1000
Customer Year Month State Dim Measures Element 2 25.5
Customer Year Month State Dim Measures Element 3 30
Thanks for the help in advance.
Exporting TM1 Cube
Re: Exporting TM1 Cube
What you need to do is this:Abinaya wrote:Hi,
- Create a view using one of your measures elements that will always have a value if any of the other elements do. If there isn't one you may need to create an artificial "flag" element using either a rule or another TI process. That will be your data source.
- On the Prolog tab, create a counter variable like l_Rows = 0;
- On the Data tab, increment that counter. ( l_Rows = l_Rows + 1;)
- Have an If() block so that If(l_Rows = 1); then write your heading row using AsciiOutput. That way your heading will be written only on the first row.
- Use CellGetN functions to retrieve your various measures elements values.
- Use AsciiOutput() to do a single output of all of the values that you want to write.
In this way as the Data tab processes each row you'll be manually reading whichever measures values you want to output, and writing them to your file in a single row.
Abinaya
- Version: 9.5.2
- Excel Version: 2003
Thanks.That worked.Alan Kirk wrote:What you need to do is this:Abinaya wrote:Hi,
