Has anyone got the error: java.lang.Integer incompatible with java.lang.String when publishing an active form in TM1 10.2 and able to fixed it?
I've tried to look for clues, but only found this: https://www-304.ibm.com/support/entdocv ... wg1PI08723
Please advise. Thanks!
publishing Active Forms in TM1 10.2
PlanningDev
- Version: 2.0.5
Re: publishing Active Forms in TM1 10.2
EDITED, sorry slightly different issue. We were getting Java.Null.Language.Pointer when refreshing a published active form.
"Already logged and accepted as a bug with IBM. They are looking to fix for RP2."
COGCQ00850463, from PMR 74318,227,000
We played around with the sheet and got the error to go away unfortunately I can't tell you exactly what it was. Take a look at any named ranges that have invalid references possibly.
