TM1 Websheet formula problem
Motyl
OLAP Product: Cognos
Post by Motyl »
I've build tm1 websheet that allow me to put data to the tm1 dimension.
But I have problem, I want to allo edit data that is in dimension
In first cell I have element name, and i can choose it thanks to subnm.
In the second cell i have attribute value, that also is dictionary:
SUBNM("CXMD:dMes1";"Miesiace";DBRA("CXMD:dMes2";B1;"From"))
When i choose something from dimension dictionary DBRA("CXMD:dMes2";B1;"From") is disapering from formula.
How to avoid this, or refresh sheet to the orginal state (rebuild from action button don't work)
Please help
Re: TM1 Websheet formula problem
Motyl wrote:Hi
Please help
In one cell you can't. Every time you make a SUBNM selection you are essentially rewriting the formula in that cell.
Why would you need the second column to be a SUBNM at all, if they are using the first to select the element with a SUBNM; just keep the DBRA part (without the SUBNM) in the second column that looks at the first.
