10.2 Operation Console with CAM
Posted: Thu Feb 13, 2014 4:23 am
I have been spending the last few days setting up various components in TM1 10.2 with CAM using Active Directory. Managed to get all the components working such as Insight, TM1 Application Portal, Cognos Workspace, Performance Modeler, TM1 Web using Active Directory. Except for Operation Console!!!
"The specified server could not be contacted" is the error message. I flipped the authentication back to TM1 native and Ops Console works perfectly hence I am pretty sure this has nothing to do with Java certificate store issue, Ops Console is working fine except with CAM.
This leads me to the following support document from IBM:
http://www-01.ibm.com/support/docview.w ... wg21650271
which require to specify CAMID when connecting to Ops Console. Problem is when I tried to enter the CAMID for the Active Directory domain user which is in a very long format that looks like this : CAMID("DomainName:u:67e9afe65410024d90572b7d65c343df"), the Ops Console login page does not accept the input format (could be due to come of the characters). Now I am stuck.
Anyone else uses CAM with AD and TM1 Operation Console and got it working ?
We have no choice but to go BI CAM path due to the issues of TM1 Web and the rest of the components not supporting the TM1 mode 3 authentication method.
