I have a client that has a string cell referenced in a bdss on a web sheet. It is visually behaving as it should in the web.
The target cell is changing color after recalc but the data is not being set to the cube nor is it displaying in the dbss. Is anyone else experiencing this? Any work arounds know?
DBSS Not functioning in TM1Web 10.2
Gabor
- Version: [2.x ...] 11.x / PAL 2.1.13
- Excel Version: Excel 2016-2021-365
Re: DBSS Not functioning in TM1Web 10.2
It seems to be broken up to TM1 10.2 FP1, but I see it's working with a pre-release of IF1 (Build 40376).
A few days ago I was told, final TM1 10.2 FP1 IF1 is scheduled for this week, not sure if this is still the case.
- wissew
- Version: 9.5.2; 10.2.2; 11
- Excel Version: 2003 SP3 - 2013
I found out that it is in the IF for FP1 and should be out this week.
Gabor
IF1 was release over the weekend, PI07408 "DBSS function not working in TM1Web 10.2" is listed as solved.
However, support needs to be involved to get access to the private section of Fix Central to be able to download the files.
